Got a little work done over the weekend, scraping (chiseling) that factory tar mat off the floorboard was a total beotch!!!!!! Got the interior about ready to lineX and start the cage build, still have to pull the dash sometime soon. Plan on going with two Mastercraft Baja RS recliners up front and one matching fixed in the rear, all mounted to the cage. Going with a tan LineX on the floor and back wall and will be leaving most of the factory interior out for good.
Also received a Saginaw (Cherokee) steering box that Tom Allen from PSC sent me to play with. As of now, the plan is to fab up a rectangular tube section with two bolt sleeves the same width as the frame rail and weld it to the top of the frame to catch the two upper mounting holes on the steering gear, then sleeving two more about mid-way up the factory frame to catch the two lower mounting holes. Even though the sector shaft is centered on the leaf spring, it appears that the box will be far enough forward that they won't hit.....hopefully :smokin:!
So far I'm leaning toward either Poison Spyder SpyderLocks or TrailReady HD17 wheels this time around.
