I spoke with the folks at Bushwacker about installing the Tundra Pocket Fender Flares on
a 08-10 Seq. According to them the front fender of the Seq and Tundra are basically the same. The rear flares are different in that the Seq uses a two piece flare for the door. The rear is of course different and will require some grinding and cutting the flare in to two pieces. My question is, can anybody confirm that the front fender panels are the same...
Riqe.
FYI (in case you didn't know) there are fender flares specifically for the Sequoia, I don't know if you're looking for a more aggressive/wider flare but it would be much easier. As far as I know the Tundra flares have a cut out for the gas tank.
They should be the same. You can bolt up a Sequoia front bumper to Tundra fenders, so I don't see why you couldn't use the front flares as long as they are the kind that stop at the top of the bumper. Good luck!
Exactly what I was wanting to confirm. I will do the mods and install the rear ones too.
