What is the CHEAPEST and EASIEST way to lift or level a 04 double cab? Prices??? Pictures??? Im not much of a off-roader just want it for looks and to add a larger more aggressive tire to my Toyota Installed Enkei 16's.
Thanks!!! I as well have a 04 tundra double cab I went with the less expensive lift because I dont off road much, I just wanted to make sure I can get up and down curbs when im in a pinch and not worring about hitting the bottom of the truck. I installed three inch toytec spacers on the struts and went with corn fed 1 1/4 inch blocks on the rear that allowed me to fit 285/70/17 bfg to add to the lift. The cost of the parts is minnor compared to adjustable coil overs ( which I would recomend if you off road). Spacers and blocks are easy to install and the truck rides the same as it did when it was stock. I have a few pictures in my gallery for you to look at.
