All websites that sells Undercover Classic for 2007+ states "works with track rail system"... Is it required for mounting? Hoping someone with Undercover can confirm it.
Nah. I actually had to have my rails cut out of the bed so that i could install the Bedrug and Undercover combo the way i wanted it. The rails make the install quicker but it's not required. It comes with hardware for mounting under the lip.
Nah, but it makes it much easier. I did my Undercover install without the rails first, then found a set and installed it with the rails. Adjustments are so much easier with the rails.
my armorlid is very similar..
mines mounted with the rails...but i helped to install one using the clamp on method on a truck that was a base truck w/o the rails....the rails really make it alot easier but its fine the other way as well.
