I have a 2006 Tundra V-6 and noted there is no way to check my automatic transmission fluid or to even add transmission fluid. I did see a drain plug and an odd looking plug to its right at the bootm of the oil pan that appears as if it can not be removed. How do I check my oil level and refill with a fluid I want inthis tranmission? Please e-mail me. Where can I buy the specil tools and plugs to this myself.
hi,it's not what you want to hear, BUT! you will never get all the fluid out.
so i highly suggest you go to a shop that knows what they are doing.
make sure they know what tranny fluid to use. toyota is a sealed unit.
so you most likely aren't low.
you are better off going to toyota for this job.
at least you know it's done the right way.
even though you will pay more.
also they usually send you coupons in the mail, use them.
good luck,
gorilla
