1 - 16 of 16 Posts
I know there are plenty of threads on this but I can't figure out if I need (2) bulbs for my headlights when I order the V-Leds. One for low and one for high? I plan on doing all of my lights inside and out. What is the best way to figure out exactly what to order?
The low beams are H11 and the high beams are 9005. I'd send you the links directly but I think that's against the rules here :( Go to the footer of our site, click on Vehicle Specific Apps, then scroll down to the Toyota emblem and you find the full list of bulbs for the 07-Up Tundra.
If you're not in a big hurry we are lowering the price by $20 a kit this weekend! Coupon code tundrasolutions gets you 15% off as well! With those kind of savings you can afford to convert both high and low beams!
I read somewhere that you should not use LED lights for headlights.
vleds - all of the LEDs (interior) I bought from you for my truck and car still doing good til this day.... frikkin' bright... don't need porch or garage lights!
LED headlights are just around the corner though, and have started to appear in production applications. I am sure Jake will have them to offer before too long.
We do not offer an LED headlight bulb. We do however sell fog light and DRL bulbs. A standard halogen bulb puts out over 1300 lumens, our high power 28 puts out 400 lm. Even though it is the brightest automotive LED replacement bulb on the market, it's no where near bright enough to see by.
How bright is your fog light 3000K (yellow) HID? I might interested in buying one if they are super yellow!
It would probably be quite a bit less than 400 lumens. In general the lower the color temperature, the less efficient the LED becomes.
I have the foot-well VLEDs to install and Cargo VLEDs on the way. Saving up for HID conversion to Heads and Fogs.
All you want to know for VLEDs and our Tundras: Welcome to V-LEDS.COM
07-Up TOYOTA Tundra
Low beam headlamp
H11
V-HIDS 35W SLIM BALLAST XENON HEADLIGHT KIT H11 6000K BLUE TINT
$99.99
High beam headlamp
9005
V-HIDS 35W SLIM BALLAST XENON HEADLIGHT KIT 9005 6000K BLUE TINT
$99.99
Fog/Driving light
9145
V-HIDS 35W SLIM BALLAST XENON HEADLIGHT KIT H10 9145 6000K BLUE TINT
$99.99
Here is an LED alternative, much safer to use than HID and provides a great match to our 6K Blue headlights
We found the HID may haze the chrome reflector in smaller housings.
V-LEDS 6K HID WHITE 28 LED 2X BRIGHTER OUTPUT DRL/FOG BULBS HB3 9005 H10 9145
$69.99
Parking light/ Front turn signal (NON DRL equipped ONLY)
4157NALL
V-LEDS AMBER 60 SACK TYPE PARK/TURN BULBS 3157 4057
$49.99
V-LEDS AMBER 92 SACK TYPE PARK/TURN BULBS 3157 4057
$69.99
Or
SWACK TYPE 2 DUAL COLOR CHANGING HID WHITE AMBER SWITCHBACK 60 LED TURN SIGNAL BULBS 3157 3157NA 3357 3457 4157 4057
$54.99
SWACK TYPE 2 DUAL COLOR CHANGING HID WHITE AMBER SWITCHBACK 92 LED TURN SIGNAL BULBS 3157 3157NA 3357 3457 4157 4057
$79.99
Front sidemarker
168
http://www.v-leds.com/Interior-LED/DomeMap-LED/Amber-LED/V-LEDS-AMBER-4-M-SMT-p7114825-1-2.html
V-LEDS AMBER 4 M-SMT 2W HIGH POWER BULBS 194 168 158
$19.99
Rear turn signal
3156
http://www.v-leds.com/Exterior-LED/Turn-Signal-LED/Amber-LED/V-LEDS-AMBER-60-M-SMT-p4835729-1-2.html
V-LEDS AMBER 60 M-SMT PARK/TURN BULBS 3157 3156 4057
$59.99
Wire into the rear turn signal circuit, takes care of the hyper flash.
3 OHM 50W 4 BULB LED LOAD EQUALIZER RESISTORS TURN SIGNAL BLINKER FIX
$14.99
2 LOAD RESISTOR MOUNTING PLATES SINGLE
$4.99
Tail/Stop light
3157
V-LEDS RED 92 M-SMT TAIL/BRAKE LIGHT BULBS 3157 3156 4057
$69.99
Other Brake Light Options:
2 RED 3157 V-LEDS 7W HIGH POWER 20 LED BRAKE LIGHT BULBS 3156 4057
$49.99
V-LEDS RED V-STAR M-SMT TAIL/BRAKE LIGHT BULBS 3157 3156 4057
$69.99
High mount stop light
921
http://www.v-leds.com/Exterior-LED/Brake-Light-LED/Red-LED/1-EA-V-LEDS-RED-14-M-p5746586-1-2.html
1 EA V-LEDS RED 14 M-SMT 5W HIGH POWER 3RD BRAKE LIGHT BULB T15 T-15 516 579 901 904 906 908 909 912 914 915 916 917 918 920 921 922 923 926 927 928 939
$24.99
Cargo area
921
V-LEDS HID WHITE 14 M-SMT 3W HIGH POWER BULBS 917 918 920 921 922 923
$49.99
License plate
168
V-LEDS HID WHITE 4 M-SMT 2W HIGH POWER BULBS 194 168 158
$19.99
Back up light
921
http://www.v-leds.com/Exterior-LED/...e-LED/V-LEDS-HID-WHITE-19-M-p7526829-1-2.html
V-LEDS HID WHITE 19 M-SMT 8W HIGH POWER BULBS 917 918 920 921 922 923
$59.99
V-LEDS HIGH POWER 18W LED BACK-UP LIGHT LICENSE PLATE FRAME
Regular Price: $99.99
Sale Price: $69.99
Glove box
74
2 V-LEDS 3 SMT HID WHITE WEDGE BASE DASH LIGHT BULBS 37 74
$6.99
You get 2 bulbs, so use the other one under the driverÂ’s side foot well.
Map light (use this for Double Cab dome light also)
168
http://www.v-leds.com/Interior-LED/DomeMap-LED/White-LED/V-LEDS-HID-WHITE-4-M-p8187987-1-2.html
$19.99
Dome light (Crewmax Only)
168
V-LEDS HID WHITE 4 LED 2 WATT HP M-SMT FLANK BULBS 194 168 158
$19.99
Step/Courtesy light (Doors)
168
$19.99
Again these are the best bulbs we sell for the 07-Up Tundra, we have many other bulbs that are a fraction of the price but going with these will give you the best results.
Much brighter than factory halogens for sure. Your looking at around 2900 lumens per side. The 3K HID is very yellow but not an ION yellow, it's hard to describe. We are working on making a 3K that looks closer to the color you get on warm-up for those of you who already have 3K HIDs, I'm sure you know what I'm talking about.
Again we are lowering the price of our kits by $20 tomorrow and you can use coupon code tundrasolutions for 15% off everything on our site. Now is a good time to buy!
Oh and thanks for posting the list TK!
Not a problem! VLEDS are awesome! Love the light output and the company is quick with delivery and cooperation!
Just put in my MAP light replacement VLEDS; it is back to looking like WHITE LIGHT! It is so awesomely bright. I can't wait to put in my floor-wells, and cargo lights which will be here next week........
Headlights to come.........
Floor wells look great! Easy install also! Cheap too!
1 - 16 of 16 Posts
