1 - 18 of 18 Posts
could someone give me the parts number for all the bulbs I can buy for the Tundra at V-leds ?
interior and exterior
Map lights... you'll love this:
V-LEDS HID WHITE 4 M-SMT 2W HIGH POWER BULBS 194 168 158
Doors and the dome lights:
V-LEDS HID WHITE 4 LED 2 WATT HP M-SMT FLANK BULBS 194 168 158
License Plates:
2 HID WHITE SMT 5 LED LIGHT BULBS 1895 53 57 182 BA9s
Go with all the High Power LEDs... you won't be disappointed. I tried both non High Power and High Power LEDs... big differences.
Warning: Remove the dome fuse, before install/replace the bulbs.
Your neighbors will get jealous when you open your truck at night with all the LEDs mentioned above installed.
I can't help you on the exterior LEDs.
Here you go. Choose whatever fits your budget
I got these under $30 with coupon and that fits me perfect!
Description:2 HID WHITE HIGH POWER LICENSE PLATE LED BULBS 194 168 158, Item #:
Unit price:$8.49 USD
Qty:1
Amount:$8.49 USD
Description:2 HID WHITE WEDGE BASE LED DASH BOARD LIGHT BULB 74 37, Item #:
Unit price:$2.12 USD
Qty:1
Amount:$2.12 USD
Description:2 HID WHITE INVERTED CONE WEDGE BASE LED 194 158 168, Item #:
Unit price:$1.69 USD
Qty:2
Amount:$3.38 USD
Description:2 HID WHITE 6 LED LIGHT BULBS 194 168 158 2825 W5W s, Item #:
Unit price:$6.79 USD
Qty:1
Amount:$6.79 USD
For those who are interested in replacing other lights on Tundra for LEDs. :thumb:
Here is the list of replacement bulbs from Osram Sylvania
2007 TOYOTA Tundra
That means, for example, maplight replacement type is 168. So you search for LEDs that qualify for that type.
Low beam headlamp
H11-55W
High beam headlamp
9005
Parking light
4157NALL
Front turn signal
4157NALL
Rear turn signal
3157A
Tail light
3157
Stop light
3157
High mount stop light
921
Fog/Driving light
9145
License plate
168
Back up light
921
Front sidemarker
168
Rear sidemarker
3157
Ash tray
74
Glove box
74
Map light
168
Dome light
168
Step/Courtesy light
168
74
Trunk/Cargo area
921
Check to make sure the flank style led will work in your year and model of truck. I have a 2010 DC RW and I don't think the flank style will work for me in the vanity light and dome light. I already ordered them though thinking they would. I plan to modify them to make them work though.
Hey guys, for your convenience we put the full list for the 07-Up Tundra right on our site. Go to the very bottom of the page and click Vehicle Specific Apps. Sorry I'd put the link in here but I don't think I'm allowed.
As I suspected the flank style ones do fit in the dome light on my 2010 Rock Warrior Double Cab. However, they do not point down. Depending on how they are installed they either point forward or backwards. The light output is good but not shining straight down. The flank style works great in the door.
My plan is to order another pair the same as used in the map light and move the flank style in the rear doors, since I forgot to order light for those anyway.
I will say these lights are super bright and look great. Beautiful white light.
That is correct, the DC uses a standard forward firing type bulb (noted in our application list). The CM uses the Flanks in the rear dome. Glad you like them kuee!
V-Leds, straighten me out here,( good luck:D) I bought V-Leds for everything but the dome-light,got a Oznium 14-Led striplight in that. The door lights don't shine downward like they should and really aren't all that bright either.Map light is "ok" but I've seen what I perseive to be brighter (in this thread). Probably bought the wrong type or number of LEDs.Got a 2010 DC, Thanks.
Nothing else needs changed? Stock fuses are ok? Sorry if stupid question, busy at work, heads not on str8.
How about a coupon code for TS members!!!
Or a group buy on 921 replacements, those suckers are expensive!!!
Thanks for the great products. have them through out the cab just want 921's for the reverse lights..
cmb: we put the full list for the 07-Up Tundra right on our site. Go to the very bottom of the page and click Vehicle Specific Apps. If you want the best results go with what we have on the list.
yanksfool: As far as interior bulbs go, no nothing needs to be changed other than the bulbs themselves. LEDs draw just a fraction of the power so no need to up the fuse rating.
SKICREW: Become a V-FAN on our facebook page (search v-leds) and keep up to date on new products and special offers. Our last promo was 20% off!
Thanks bro! So that applies to the courtesy light on the side mirrors too I take it? Need to pull the fuses when changing?
1 - 18 of 18 Posts
