In my 01 tundra, the driver side vent that is on the dash next to the window doesn't blow regardless of which setting the control is on. I don't know much about this stuff. Any ideas what the problem is, and even better, how to fix it? Thanks in advance!
I had this. The actual vent line was slightly disconnected right near the drivers side kickplate on my truck. There is a connection right above the brake pedal. I had to just squeeze the two section together again. The air flow is still not as strong as the other vents but it does come out.
Forum Admin
You may want to check the ducting under the steering column. There is a removable black section of duct that may have come loose. You can access it fairly easily with a 10mm socket and some plastic clip wiggling. There is also some foam on the edge of the connecting duct pieces, may help if you R&R that stuff.
Good luck!
