I like knowing what things mean and VIN numbers have always intrigued me. So, I searched and found a great resource for 2005 Toyota's and although it is for the 2005 model year, I'm sure the info would be helpful for pre and post 2005 years.
Link is to downloadable PDF:
http://www.weber.edu/wsuimages/automotive/T-TEN/2005 VIN Toyota.pdf
Be sure to look at 2nd portion of spots 4 and 7. Spot 4 describes the body type but there are separate sections for passenger cars and multipurpose passenger vehicles. Spot 7 is used for either Restraint System or Grade... for passenger vehicles, it pertains to restraint system and for multipurpose passenger vehicles, it pertains to grade... SR5, Limited, etc.
Here you go!
[FONT=Arial,Bold]2005 VEHICLE IDENTIFICATION NUMBER
Vehicle Description Section (VDS)
World Manufacturer Identifier (WMI)
Check Digit
(VIS) Vehicle Indicator Section
[FONT=Arial,Bold]JT2 DG12T OXO 049506[/FONT]
[FONT=Arial,Bold]1. World Source:[/FONT]
J = Japan
1 = NUMMI
2 = Canada: TMMC
3 = Mexico: TMMBC
4 = USA: TMMK
5 = USA: TMMI & TMMCA
[FONT=Arial,Bold]2. Manufacturer:[/FONT]
T, N = Toyota
[FONT=Arial,Bold]3. Vehicle Type:[/FONT]
D, K, X, 1 = Passenger Vehicle
D, E, L = Multipurpose Passenger Vehicle
B, E, M = Truck
[FONT=Arial,Bold]4. Body Type/Drive Type:[/FONT]
[FONT=Arial,Bold]Passenger Vehicle:[/FONT]
A = 2Dr Sedan 2WD
B = 4Dr Sedan 2WD
C = 2Dr Coupe 2WD
D = 3Dr Liftback 2WD, 3Dr Coupe 2WD
F = 2Dr Convertible 2WD
K = 5Dr Sedan, 4Dr HB 2WD
L = 5Dr Station Wagon 4WD, 5 Dr Sedan 4WD
[FONT=Arial,Bold]Multipurpose Passenger Vehicle:[/FONT]
D, G = 4Dr Wagon 2WD, 5Dr Wagon 2WD
E, H = 4Dr Wagon 4WD, 5Dr Wagon 4WD
K, Z = 5Dr Wagon 2WD
B = 5Dr Wagon 4WD
M= 5Dr Van 2WD
[FONT=Arial,Bold]Truck:[/FONT]
[FONT=Arial,Italic]Standard Wheel Base (Tundra)[/FONT]
B = Large Cab 4WD K = STD Cab 4WD
J = STD Cab 2WD R = Large Cab 2WD
[FONT=Arial,Italic]Short Wheel Base (Tacoma, Tundra)[/FONT]
N = STD Cab 1/2 Ton 2WD
P = STD Cab 1/2 Ton 4WD
[FONT=Arial,Italic]Extra Long Wheel Base (Tundra)[/FONT]
E = Double Cab 2WD
D = Double cab 4WD
[FONT=Arial,Italic]Long Wheel Base (Tacoma)[/FONT]
T = Extra Cab/Access 2WD
U = Extra Cab/Access 4WD
J = Double Cab 2WD
L = Double Cab 4WD
[FONT=Arial,Italic]Super Long Wheel Base (Tacoma)[/FONT]
K = Double Cab 2WD
M = Double Cab 4WD
[FONT=Arial,Bold]5. Engine Family:[/FONT]
A = 3MZ-FE F = 1MZ-FE T = 2UZ-FE, 1NZ-FE
B = NZ-FXE K = 2GR-FE U = 1GR-FE
D = 2AZ-FE P = 3MZ-FE W = 3MZ-FE
E = 2AZ-FE R = 1ZZ-FE X = 2TR-FE
Y = 2ZZ-GE
Digits
[FONT=Arial,Bold]6. Series:[/FONT]
0 = UZJ100L(LC) NHW20L(Prius) ZZT230L(Celica)
1 = ANT10L(tC) TRN220L(Tacoma) ZZT231L(Celica)
GRN210L(4Run) TRN225L(Tacoma) ZZW30L(MR2)
GRN215L(4Run) GRN225L(Tacoma)4 = GRN245L(Tacoma)
NCP12L(Echo) 3 = ACV30L(Camry) TRN240L(Tacoma)
UZN210L(4Run) MCV30L(Camry) TRN245L(Tacoma)
UZN215L(4Run) MCV31L(Solara) UCK40L(Tundra)
2 = ACA23L(RAV4) NCP31L(xB) UCK41L(Tundra)
ACA28L(RAV4) UCK30L(Tundra) UCK45L(Sequoia)
ACU20L(Hlander) UCK31L(Tundra) 5 = GRN250L(Tacoma)
ACU25L(Hlander) UCK35L(Sequoia) 6 = TRN260L(Tacoma)
MCL20L(Sienna) ZZE130L(Corolla) TRN265L(Tacoma)
MCL23L(Sienna) ZZE132L(Matrix) GRN265L(Tacoma)
MCL25L(Sienna) ZZE133L(Matrix) NCP61L(xA)
MHU23L(Hlander) ZZE134L(Matrix) 7 = GRN270L(Tacoma)
MHU28L(Hlander)
[FONT=Arial,Bold]7. Restraint System/Grade:[/FONT]
0 = Manual Belts w/ 2 Airbags, Side Airbags, and
Curtain Shield Airbags (Front & Rear Seats)
2 = Manual Belt w/ 2 Airbags
6 = Manual Belt w/ 2airbags, side airbags, curtain shield airbags
and knee air bags (driver seat)
7 = Manual belt w/ 2 airbags and knee airbag (driver seat)
8 = Manual Belt w/ 2 Airbags and Side Airbags
[FONT=Arial,Bold]Multipurpose Passenger Vehicle/Truck:[/FONT]
2 = DLX, Base, XLE 6 = SR5
3 = LE, XLE, CE 7 = Limited (4Runner)
4 = SR5 8 = Limited (Tundra, Sequoia)
5 = VX 9 = CE
[FONT=Arial,Bold]8. Car Line:[/FONT]
A = Highlander, Sequoia V = RAV4
B = Avalon N = Tacoma 0 = MR2
C = Sienna P = Solara 1 = Tundra
E = Corolla, Matrix R = 4Runner 3 = ECHO
J = Land Cruiser T = Celica 4 = Scion xA, xB
K = Camry U = Prius 7 = Scion tC
[FONT=Arial,Bold]9. Check Digit:[/FONT]
Internal use only. Used by Toyota
and FBI computers to verily the VIN.
Digits
[FONT=Arial,Bold]10. Model Year:[/FONT]
5 = 2005
[FONT=Arial,Bold]11. Plant Code:[/FONT]
0-9 = TMC S = Indiana
C = Canada Z = Fremont (CA)
U = Kentucky M = Baja California
[FONT=Arial,Bold]12-17. Serial Number[/FONT]
The information above was copied from Toyota Technical Training on 2005 Vehicle Identification Number, Rev 9/20/04. All credits to Toyota.[/FONT]
Here you go!
Check Digit
J = Japan
1 = NUMMI
2 = Canada: TMMC
3 = Mexico: TMMBC
4 = USA: TMMK
T, N = Toyota
B, E, M = Truck
A = 2Dr Sedan 2WD
B = 4Dr Sedan 2WD
C = 2Dr Coupe 2WD
B = 5Dr Wagon 4WD
M= 5Dr Van 2WD
E = Double Cab 2WD
D = Double cab 4WD
J = Double Cab 2WD
L = Double Cab 4WD
K = Double Cab 2WD
M = Double Cab 4WD
Y = 2ZZ-GE
Digits
MHU28L(Hlander)
5 = VX 9 = CE
Digits
5 = 2005
