I’m new here so bear with me. Started truck this morning and noticed the VSC OFF light is on on dash. Is this normal? I can hit a switch on dash to turn lite on/off. Now I’m not sure if light should be on all time. Help?!
Will do. Thanks again!That sounds more like you are throwing some sort of code. Not necessarily a huge deal but you could go to your local auto parts store and see if they will check it for free as most will. If someone hit one of the ABS wires around one of your wheels, yes, possible it could have done it but could also just be coincidence. The only way to know for sure is get it read and make sure you get the actual fault code, if there is one. If you do get a code number you can google search it or search it on here.
Fuel mileage effects. As was pointed out, VSC is normally on.No to which??
When this started to happen to me it just got worst. Heard brake rotor rubbing backing plate then it wore away the plate. Long story short my rear wheel bearings went bad, and it leaked oil on the speed sensor. That made the sensor not work then a bunch of lights come on the dash. $1500 later it was fixed new plates rotors and bearings.Fuel mileage effects. As was pointed out, VSC is normally on.
There is a spreadsheet on the site that will help diagnose issues by what lights are on or flashing. Or, as cheapskate said, parts stores will often read the codes for free.
Flashing dash lights explained ...... or maybe not
As many of you are aware, I have been working on a spreadsheet to try to sort out the meaning of the various dash light patterns which occur when there is a problem. While it has not produced the results that I expected, it does seem to have some value so I am attaching a copy of it here: I...www.tundrasolutions.com
Cheapskate, thanks so much for the explanation on VSC. Weirdest thing happened today; as I was leaving auto parts store, started truck & noticed VSC & traction dash lites came on & blinking. I turned truck off & restarted, same thing. Drove home(maybe a mile), turned truck off & back on, everything looked normal. Have not had it occur again(yet!) but don’t know what caused it. I did have brakes serviced(rotors turned) several days ago. Could that have had an effect? Anyway thanks again!
Hello good evening if your VSC LIGHT WITHOUT THE LITTLE CAR WITH THE SQUIGGLY LINES ON IT AND THE CHECK ENGINE LIGHT IS OFF. It will be your speed sensors. It could be one or two, but I would replace h Th hem all.I’m new here so bear with me. Started truck this morning and noticed the VSC OFF light is on on dash. Is this normal? I can hit a switch on dash to turn lite on/off. Now I’m not sure if light should be on all time. Help?!
