my truck did not come with the 115VAC/100W power outlet. you know this is where there is a push button marked "AC115V" in the center console and a little door that swings down to access the outlet just below the rear cup holders.
i imagine most vehicles come with the same harnesses so couldn't i just buy the parts from toyota then plug and play?
I'm also interested in doing this.
You would probably be better off purchasing a more powerful aftermarket inverter, and buying the OEM switch and outlet. I think if you want the OEM outlet in the back, you have to purchase a new center console = $$$$
