1 - 10 of 10 Posts
2 questions..... Just picked up a gorgeous one owner Black 02 Tundra TRD V8 4x4 X cab for my girlfriend. She wants to get some larger tires so I was thinking about FJ wheels and tires after doing some research... I wanted to grab a factory Navigation for her as well.... Does anybody have either, and will I need to modify anything to install? Thanks..
Not sure about the wheels but as far as a indash navigation unit goes get an aftermarket one, its easier, cheaper and does more than a stock navi. But if your bent on putting a OEM one in theres a thread floating around here somewhere (search for navigation etc) that has part numbers and details about installing a factory navigation, I think its from a solara or camry....anyway just try searching around.
heres 1: http://www.tundrasolutions.com/foru...27353-solara-navigation-install-on-04-tundra/
There was no stock navigation for the 1st-gen Tundras. And if you are adding bigger tires, do not go any bigger than 265/75-16 or 265/70-17 on a stock suspension.
Then it was very late in the series. Would it fit in an '02?
Searching on toyotapartszone it looks like it started in '04......but you can make it work in a '01-'03 w/ enough time and wiring know-how. Thats why I said itd be easier just to install an aftermarket navi unit.
And if you are adding bigger tires, do go any bigger than 265/75-16 or 265/70-17 on a stock suspension.
I think you missed a "not" in there.....anything larger than those on a stock setup will rub....
You are correct. I fixed it in my post.
Yep, its easier to get aftermarket Navi unit. But I like challenge and got my self latest Navigation Unit installed into my 2001 Tundra (I has same options as 2010 Tundra Navigation. XM Radio, Bluetooth, Back-up Camera, 4CD MP3/WMA Changer, iPhone/iPod input, etc...)
1 - 10 of 10 Posts
