DRAGON INTAKE
Weapon*R Dragon Intake Systems are CNC Mandrel Bent out of 6061 aluminum, and then Hand Tig Welded to ensure a positive seal and proper fitment. Each intake system is carefully tuned, by matching the engines displacement, air intake capacity and airspeed to the intake systems tube size and length, maximizing every engines performance output. This Intake is matched with our World Famous Dragon Filter, which provides maximum airflow, with the protection of high quality dense Poly Urethane Foam. Many studies have shown Flow rates of up to 80% more Air and Better Dirt Filtration with Foam Filter than the conventional cotton filter. The Dragon Filter features a Computer CAD Designed and Flow benched Tested Velocity Stack, which greatly increases airflow and air volume into the engine, therefore increasing engine performance. Another one of the Dragon Filters positive features are the capability to be disassembled to be cleaned and then re-assembled after cleanings or to change the color of the foam filtering element.
SECRET WEAPON INTAKE
SECRET WEAPON INTAKE – POLISHED
SECRET WEAPON INTAKE – LIMITED EDITION NEO
The Secret Weapon Intake was designed, to increase air intake volume to the engine. The concept is to create two different air velocity profiles, one traveling at higher speeds than the other. This technology increases air volume and speed to the engine, which naturally feeds the engine 3x more air than the conventional air intake system. The intake pipe is bent out of high quality 6061 Aluminum on our Automated CNC mandrel bender. Polished to a high show quality finish. The SW1 Air filter features a tuned velocity stack to increase velocity and decrease turbulence. 1 Million Mile Limited Warranty. Open pore high density re-usable foam filter.
OPTIONAL COLD AIR BOX – ADD-ON. AVAILABLE FOR SELECT APPLICATIONS
OPTIONAL RAM-AIR ADD-ON
4RUNNER - 05-08 - Secret Weapon Intake System - 4.7L V8
4RUNNER - 08-09 - Secret Weapon Intake System - 4.0L V6
4RUNNER - 85-95 - Air Flow Meter Intake Adapter Kit -
4RUNNER - 90-95 - Dragon Intake System - 3.0L V6 EFI
4RUNNER - 90-95 - Secret Weapon Intake System - 3.0L V6 EFI
4RUNNER - 96-98 - Dragon Intake System - V6
4RUNNER - 96-98 - Secret Weapon Intake System - 3.4L V6
4RUNNER - 99-04 - Dragon Intake System - 3.4L V6
4RUNNER - 99-04 - Secret Weapon Intake System - 3.4L V6
CAMRY - 02-05 - Dragon Intake System - V6
CAMRY - 02-05 - Secret Weapon Intake System - 3.0L/3.3L V6
CAMRY - 02-06 - Dragon Intake System - 4Cyl
CAMRY - 02-06 - Secret Weapon Intake System - 2.4L 4Cyl
CAMRY - 07-08 - Secret Weapon Intake System - 2.4L 4Cyl
CAMRY - 07-08 - Secret Weapon Intake System - Limited Edition NEO - 2.4L 4Cyl
CAMRY - 92-93 - Dragon Intake System - CAMRY 3.0L
CAMRY - 92-93 - Secret Weapon Intake System - 3.0L V6
CAMRY - 92-97 - Dragon Intake System - 2.2L 4Cyl - 5-Speed Carb Only
CAMRY - 92-97 - Secret Weapon Intake System - 2.2L 4Cyl
CAMRY - 94-96 - Dragon Intake System - CAMRY 3.0L
CAMRY - 94-96 - Secret Weapon Intake System - 3.0L
CAMRY - 97-01 - Dragon Intake System - CAMRY 3.0L
CAMRY - 97-01 - Secret Weapon Intake System - 3.0L V6
CAMRY - 98-01 - Dragon Intake System - 4Cyl
CAMRY - 98-01 - Secret Weapon Intake System - 2.2L 4Cyl
CELICA - 00-05 - Dragon Intake System - GT/GTS
CELICA - 00-05 - Dragon Intake System with Airbox - GT/GTS
CELICA - 00-05 - Secret Weapon Intake System
CELICA - 00-05 - Secret Weapon Intake System - Limited Edition NEO
CELICA - 00-05 - Secret Weapon Intake System with Airbox
CELICA - 90-99 - Dragon Intake System
CELICA - 90-99 - Secret Weapon Intake System
COROLLA - 03-08 - Dragon Intake System - S - 4Cyl
COROLLA - 03-08 - Secret Weapon Intake System - 1.8L
COROLLA - 03-08 - Secret Weapon Intake System - S - 4Cyl
COROLLA - 03-08 - Secret Weapon Intake System - Limited Edition NEO - 1.8L
COROLLA - 03-08 - Secret Weapon Intake System - Limited Edition NEO - S - 4Cyl
COROLLA - 09-10 - Secret Weapon Intake System - including S - 1.8L 4-Cyl DOHC WT-I SFI
COROLLA - 10-11 - Secret Weapon Intake System - Limited Edition NEO - including S - 1.8L 4-Cyl DOHC WT-I SFI
COROLLA - 90-97 - Dragon Intake System - 1.6L/1.8L
COROLLA - 90-97 - Secret Weapon Intake System - 1.6L/1.8L
COROLLA - 98-98 - Dragon Intake System - 1.8L
COROLLA - 98-98 - Secret Weapon Intake System - 1.8L
COROLLA - 99-02 - Dragon Intake System - 1.8L
COROLLA - 99-02 - Secret Weapon Intake System - 1.8L
COROLLA - 99-02 - Secret Weapon Intake System - Limited Edition NEO - 1.8L
COROLLA - 09-10 - Dragon Intake System - 1.8L
ECHO - 00-04 - Dragon Intake System -
ECHO - 00-04 - Secret Weapon Intake System - 1.5L
FJ CRUISER - 06-08 - Secret Weapon Intake System - 4.0L V6
HIGHLANDER - 01-04 - Dragon Intake System - 2.4L 4Cyl
HIGHLANDER - 01-04 - Dragon Intake System - 3.0L V6
HIGHLANDER - 01-04 - Secret Weapon Intake System - 2.4L 4Cyl
HIGHLANDER - 01-04 - Secret Weapon Intake System - 3.0L V6
MATRIX - 03-08 - Dragon Intake System - 4Cyl
MATRIX - 03-08 - Secret Weapon Intake System - 4Cyl
MATRIX - 03-08 - Secret Weapon Intake System - Limited Edition NEO - 4Cyl
MR2 - 00-03 - Cold Air Intake Box - MRS
MR2 - 00-04 - Dragon Intake System - MRS 1.8L
MR2 - 00-04 - Dragon Intake System with Airbox - MRS 1.8L
MR2 - 00-04 - Secret Weapon Intake System - 1.8L 4Cyl
MR2 - 00-04 - Secret Weapon Intake System - Limited Edition NEO - 1.8L
MR2 - 00-04 - Secret Weapon Intake System with Airbox - 1.8L 4Cyl
MR2 - 85-89 - Dragon Intake System - non-Supercharged
MR2 - 85-89 - Secret Weapon Intake System - non-Supercharged
MR2 - 85-95 - Air Flow Meter Intake Adapter Kit -
MR2 - 90-95 - Dragon Intake System - non-Turbo
MR2 - 90-95 - Secret Weapon Intake System - non-Turbo
PASEO - 92-99 - Dragon Intake System - DOHC
PASEO - 92-99 - Secret Weapon Intake System - DOHC
PICKUP - 84-95 - Dragon Intake System - 2.4L EFI
PICKUP - 84-95 - Secret Weapon Intake System - 2.4L EFI
PICKUP - 85-95 - Air Flow Meter Intake Adapter Kit -
PICKUP - 90-95 - Dragon Intake System - 3.0L V6 EFI
PICKUP - 90-95 - Secret Weapon Intake System - 3.0L V6 EFI
RAV4 - 96-00 - Dragon Intake System - 2.5L 4Cyl
RAV4 - 96-00 - Secret Weapon Intake System - 2.5L 4Cyl
RAV4 - 01-05 - Dragon Intake System - 2.0L 4Cyl
RAV4 - 01-05 - Secret Weapon Intake System - 2.0L 4Cyl
RAV4 - 06-08 - Secret Weapon Intake System - 2.4L 4Cyl
RAV4 - 08-08 - Dragon Intake System - V6
RAV4 - 08-08 - Secret Weapon Intake System - V6
RAV4 - 09-10 - Secret Weapon Intake System - 2.5L 4Cyl
RAV4 - 09-10 - Secret Weapon Intake System - Limited Edition NEO - 2.5L 4Cyl
SEQUOIA - 01-04 - Secret Weapon Intake System with Airbox - 4.7L V8
SOLARA - 02-05 - Dragon Intake System - 3.0L/3.3L V6
SOLARA - 02-05 - Secret Weapon Intake System - 3.0L/3.3L V6
SOLARA - 02-06 - Dragon Intake System - 2.2L 4Cyl
SOLARA - 02-06 - Secret Weapon Intake System - 2.2L 4Cyl
SOLARA - 98-01 - Dragon Intake System - 2.2L 4Cyl
SOLARA - 98-01 - Secret Weapon Intake System - 2.2L 4Cyl
SOLARA - 99-01 - Dragon Intake System - V6
SOLARA - 99-01 - Secret Weapon Intake System - V6
SUPRA - 86-92 - Secret Weapon Intake System - Cold Air - Turbo - with AFM
TACOMA - 05-07 - Secret Weapon Intake System - 4.0LV6
TACOMA - 00-04 - Secret Weapon Intake System - 2.7L 4Cyl
TACOMA - 95-03 - Air Flow Meter Intake Adapter Kit - 4Cyl
TACOMA - 95-99 - Dragon Intake System - 2.7L 4Cyl
TACOMA - 95-99 - Secret Weapon Intake System - 2.7L 4Cyl
TACOMA - 99-03 - Dragon Intake System - 3.4L V6
TACOMA - 99-03 - Secret Weapon Intake System - 3.4L V6
TERCEL - 91-94 - Dragon Intake System - 1.5L SOHC
TERCEL - 91-94 - Secret Weapon Intake System - 1.5L SOHC
TUNDRA - 08-08 - Secret Weapon Intake System - 4.7L V8
TUNDRA - 00-04 - Secret Weapon Intake System with Airbox - 4.7L V8
YARIS - 06-11 - Dragon Intake System - 1.5L 4Cyl
YARIS - 06-11 - Secret Weapon Intake System - 1.5L 4Cyl
GO TO NOPI WEAPON-R Catalog for more specific details
Contact the salesmen below or PM me for "TUNDRA SOLUTIONS" deal
