I am trying to get some information. I have had the issue of vibration and pulling from my front end. I have an 05 tundra xsp with the 20" enkei rims on it. Well after they made the corrections for the ball joint recall I am get an odd wear on the inner surface of the tire. It almost looks like it is rubbing on something inside the wheel well. Is anyone else having this problem or know anything of it?
When you say "inner surface", do you mean the inside edge of the
road surface of the tire, or do you mean the inside
sidewall of the tire showing the rubbing?
If it is the edge of the road surface of the tire, a previous poster is correct. The toe is off. Get it back in and properly aligned with DJ's specs.
If it is the inside sidewall, you're rubbing against something in the wheel well and/or the UCA. With a 20" Enkei, I'm not surprised. What size tire are you running? If it is too large for the fitment, you're going to need more spacing/offset adjustment to get it to stop.
