41 - 60 of 11414 Posts
Dirty as hell but before work I swapped center caps, the discs came with them, the short caps are the new.
Beer Me
I've never had great success with blocking the noise from the vents on the back wall of the cab. Since it's been raining lately, I've been extra bothered by the sounds. Those flaps inside the vents also rattle when my sub hits, which keeps me from using my sub. I was walking through Home Depot yesterday and had a thought... sponge.
I picked up two grouting sponges, $1.97 each and cut rectangular cubes out of them which I stuffed into the holes in the vents. I think the sponge is porous enough to allow pressure to breathe, yet dense enough to block the noise. I tried it this morning and so far it's working to keep the sound down, no rattle sound either.
do what i did in my truck, tear those Fxckers out! ... and no they dont leak :D
Wow Zapco you're AC looks clean, whoops back to topic...finally *fixed* passenger foglight, tweaked lamp prongs and a few dabs of silicone to hold lamp in a broken harness(tab that holds bulb broken, since I bought it). It's tight but I'ma keep an eye on it while I find a new harness.
Sweet thread!!! Received my Toytec blocks, diff drop, brake relocate, and u bolts today! Just waiting for the bilstein adjustables to get here.
Moderator
Drove to work and back. Thought more about the clunk, about electric fans, a new exhaust, re-working the scoop, the need for a serious in-depth detailing. . . . parked next to another Tundra at work (Protection in numbers in a Teamsters parking lot).
I looked at it sitting up on jack stands without a lower control arm in the rain.
I've been tempted to cut the vents out and seal over them, but stuffing them works so far.
Opened the door (again) to get the ice scraper out so that I could scrape the ice off my sister's Corolla that I am using until I can get the Tundra fixed. Hoping to open the door Wednesday and actually start it and drive it to the mechanic. Baby steps...baby steps.
John
Today I replaced my fogs with Rigid Industries 4" light bars... They fit perfectly (with a little modification...) Would anyone be interested in a how-to on this? INSANELY bright.
Here is another pic of them with the 10" light bars behind the honeycomb grille... (And my custom SickHID's!)
  • Like
Reactions: HardYakka
Drove to work, put some trash in the bed, took the trash to a dumpster, drove around town, thought about how bad I need to change my timing belt, thought about if changing my timing belt would help the weird noise my engine is making, thought about how long I have until my rear end goes out (if it's actually going out :confused:), drove home, thought about how much cooler my rims are than tundrunk's, and sat on here worrying about things on my truck that probably aren't even broke.
Thought about giving it a bath... Laid on couch and watched TV instead. Jumped in the truck to run some errands and wished I washed and lubed my balls before I left.
Got mine stuck in the mud. =]
I got stuck waaaaay worse than that (framed it out) and got out under my own power. :D
I would LOVE to get some SickHIDs.
I drove it up to the DMV and bought it a new yellow sticker for it's license plate.
Beer Me
we have different definitions of "fit perfectly"; i don't consider a square light mounted in a round hole as fitting. how much did those set you back?
lmao now that is sig worthy!!!
the thing about those, is its cheaper to get a set of dually d2's and the d2s are just as bright,
the 4" E Bar retails for $235 (each)
Let's see some up close photos with the lights off.
