1 - 13 of 13 Posts
I am building an enclosure for under the rear seat of my 2007 double cab. I have measured but it looks like I can only get 5.25" depth. Is this true or can I go deeper? I don't want to have to modify the seats or anything lime that. I searched bit didn't find any threads with clear dimensions or anything.
Is there any way to raise the rear seats at all without messing up the function or alignment of the seat? 3/4 " would be great
5 -5.5" is about max for under the DC seats. You can raise the bottoms up slightly by adding washers under the floor mounts. I did this and it gave me about an extra 1/4". Didnt affect the seats in any way.
Another idea is when youre building your box, use 1/2" MDF for the bottom instead of 3/4", this will give you some much needed extra room under the seat, but at the same time it wont change the interior dimensions of the box.
Is 1/2" mdf ok to use. I heard 3/4 was the way to go
1/2" is fine on the bottom, but use 3/4" for the rest of the box. The floor is supporting the weight on the bottom, and for these small boxes you'll be fine with a 1/2" bottom. I did this on my second and third boxes and they came out great, plus with the washers under the floor mounts, I gained about 1/2-3/4" of much needed clearance. Gives some extra room for the excursion of the cone.
Roll Tide! I happened to ask the same question and got the tutorial from the other site. I don't know that I want to redrill holes because if the thread doesn't match those of the screws, then you are screwed! No pun intended. I am debating on sticking with my little 8" sub and get one more or go with an under the seat box with 2 10s. I have to decide soon so I may exchange the sub for the 2 10" woofers. I was looking at a ported box more so then the sealed, but at this point, am not totally sure.
I think I'm going with a single 12" RE SL. We'll see how it turns out.
I ordered the box that houses 2 10s and is ported. For subs, I am going with JL 10W0s. I really like the 8" sub, but I want to be able to crank it from time to time. I don't need to be heard 2 blocks away, I just want more bass than it puts out. I am returning it to crutchfield and will go with a some W0's. JL makes some great subs. I know that the RE subs are really good subs too! Keep us posted. The bad thing about the box I am getting is that it only comes in gray and my interior is black. I can recarpet the parts exposed so it will look nicer though. We'll see.
I didn't really like the shallow sub options that I had and wanted to come up with a stealthy solution. I've kind of taken a page out of JL Audio's playbook and designed and built this rear firing dual 8" box for my DC:
It's right at 16" long (front to back) and will house two RE Audio REX8s. Comes in at .7 cu. ft. total, taking into account driver displacement.
-Wes
Discussion Starter · #13 ·
That is a nice looking enclosure. Let us know how it turns out. It will be a while before I get the install done. I am building my system a little bit at a time. Cash is a little tight and I still have to buy the head unit and amp. I'll deffinately post some pics when I can install everything
1 - 13 of 13 Posts
