1 - 14 of 14 Posts
Hello all,
Been a while since I have posted.
Frame rusted out at rear of front wheel wells where the frame bends in and up. I just don't want to junk the truck, wondering if anyone has any suggestions?
Picture of the frame is the good side the inside collapsed when my mechanic put it on the lift.
Driving a 2016 DC Inferno now.
03 limited ac 4x4
I’m pretty new to the tundra world, but I would assume there is a way to replace or at least reinforce the frame so it wouldn’t do that.
Damn, we should put the body on the frame of my truck.
My clear coat is almost all gone, but I have zero rust underneath.
That's the problem and benefit of living in the desert.
Your truck body looks great and something must be done underneath.
Discussion Starter #5
Zbrower1, Two frame guys, my mechanic and a body guy all said its not worth it. Needs some other work under there also. Dealership documented it as unsafe to drive.
tempetom, Yep a lot of salt here around Chicago
Datzen, Your making my Wife nervous
My guess is it boils down to how much time you have, how many tools you have, and how good you are with those tools. Thats one damn fine looking truck but if you dont have the time or the tools, like a lift too, then you might be better off to just pull the plug and sell it as is.
Now go get your 2016 rustproofed before it ends up like that one does.
  • Like
Reactions: tundrunk
Hello all,
View attachment 152167 View attachment 152168 View attachment 152169 View attachment 152170
I suggest you drive your truck into the service bay, get out and refuse to move it until you get written satisfaction to this issue
Hello all,
Hello all,
You truck is gorgeous. I have a 2004 that had the exact rust in the same place. Toyota knew about it for 5 years. I don't have my paperwork right now showing when it was done, but I got and entire new frame installed under my 2004 Tundra. FREE. They replaced the FRAME for FREE, and an entire brake caliper and control arm. FREE. I'm a very nice person, but when they tried to lie their way out of it, I looked at the service manager and told him "I'm and 800 lb. gorilla when someone tries to cheat me'. He found out when I set up the general manager with the owner, got some language in emails i received from them and then went to town. Since then, all of the Toyota Dearler's have had rusted frames piled in a heap behind the dealership. I'm talking 30 at one dealership in Fredericksburg, VA. I put a 4x8 sheet of plywood standing up lengthwise in the bed, and spray painted all kinds of stuff, tied it down properly and drove it in and around the dealership on a Saturday and then parked across the street for 3 hours. They called the cops. Cops came, I was polite. They said I could stay where i was, but they didn't want to have to come back a second time. I'm sure they are still playing the blame game on owners. I a construction contractor, so I called BS every time they started back up. I send an email to Toyota USA in California that was so nasty, but proper. I have never shown it to anyone since then. There going to tell you it's an 16 year old truck, and not their problem. If I was you, I'd walk into another dealer and ask the service manager ""when was the last time you changed out a frame on a 2004''. or How many 2004 frames have you ahd to replace. Make it sound like genereal converstaion, so he's not immedately on guard. I had my phone on record when i told the service manager i was a 800 lb. gorilla when i'm cheated. I got throught to the general manager by creating an email [email protected]. He called me to inform me that my truck was originally bougth in upstage New York, where they use a lot of salt. I turned that into Toyota General Managers states that Tundras are not fit to be used in half of the United States. I also sent it to the owner of the three toyota dealerships around Washington DC. Good Luck my friend.
Nice! I have a 2003 in F'burg. I need to visit that dealer as I was told nothign could be done.
Thank You!
What would you want to sell it for? I can use the parts.
Well you have 2 choices....replace frame, or buy new truck. Yours is a lot better looking than mine was, but my frame was solid, recalled of course.
Can you order just a frame? I looked a while back because mine is starting to get scale rust between the fuel tank cross member and the frame.
Mine is an 01 and at the time of the recall it didn't meet the criteria for replacement. I have modified it pretty substantially since then so I really doubt its covered.
Sean
I know some frame repairs were done well past when the issue was identified. My 2001 had crossmembers replaced in 2012 (according to service records).
There mayyy be a way to get the dealer to cover this under the recall/settlement. May a letter a from a lawyer? I don't know the best approach.
1 - 14 of 14 Posts
