1 - 20 of 35 Posts
06DC limited TuRD 6,500 miles
Fixed::tu:
1) Sun/moon roof rattle/scratch/loose cross beam.
2) Blown right rear shock-BILSTEIN (factory trd)
Not Fixed::td:
3) High pitch whistle while under heavy acceleration (not yet fixed)
4) lower ball joint (going in soon)
Not fixed caused by:devil:
5) Upper ball joint (seals tore, left and right) caused by 3 inch spacer lift (sits on top of shock assy) (getting fixed with lowers) Dealer is going to cover it because they are the ones that recommended that lift kit!.
6) flaw in front passenger seat material. (A row of fibers missing that stick through the backing). F_ING Dog! Funny thing is my dog jumped in and out of my old 93 dually and the material never got scuffed/tore ever. (getting fixed w/ball jo..)
33000+ and nothing yet!:tu:
Got the recall notice sitting on my desk at home so I'll get that done in a couple weeks and I do have a rattle in my moonroof, sounds like parpar1's problem. I had them look at this one time it was in for routine stuff but they couldn't find it, said I'd have to leave it overnight as it happens more when it's cold:rolleyes:
So far I'm pretty pleased!
33K
1. LBJ
2. Left front turn signal housing
Lower ball joint And free align
Replaced both front door sills under warranty because the Good Guys broke them while installing my stereo. (Thanks Toyota)
Replaced driver side window moulding due to someone trying to use a slim jim on it. (thank you Toyota)
2 years 40k +
Drivers side mirror vibrating
Drivers door wheather strip (really was hurricane damage) but Toyota of Hollywood hooked me up
Ball joint recall in the schedule
Driven daily like I stole it .No babying the baby.
Lower ball joint recall-Thanks mustang67408!!
Blower motor replaced-twice!!
Leaking battery
Squeaking passenger side seat
38k and I am on my third set of front brake pads. I am heavy on my brakes.
blower motor the first year and a leaky battery, both in 2004
nothing else since
i've been in once for rough idle at cold start up, brake pulsation, ball joint recall and gas nozzle falls out of fuel filler neck when pump shuts off. of course the dealer could noy verify problems except recall.....go figure. i have less than 5k on it.
* passenger side armrest loose - missing parts from original install or when leather added at port.
* a/c pipe leading to condensor leaking - new condensor and line plus fresh charge refrigerant
* blower motor replaced due to squeeking tsb
* front shocks replaced due to cracked plastic cover
* rear shocks replaced due to squeeking tsb
i solved my own vibration problems, aligned to DJ's specs, replaced stock muffler, added JBA headers.
Mech. Engr. / Mechanic
Just got mine 6 mo. ago and only 4700 miles so nothing yet! :tu: Just got my LBJ recall notice today in the mail. Hopefully, that'll be it for a long time.
1 - 20 of 35 Posts
