Hello all,
I have a 2005 DC with the Tokiko shocks on it. They need replaced. I've been told that Bilstein's would be the way to go, but I don't want a stiff ride in particular. Almost all my driving is on paved roads.
So, I've been told the original blue/yellow TRD Bilsteins would be better than Tokiko, but still not too stiff. Trouble is, which part number do I look for? Is it
48510-AF140
or
48510-A9310
or
48510-09350 ?
All of these have been mentioned at one time or another, so I'm confused.
Josh
48510-A9310 is for a 4wd DC w/offroad package that supersedes part #48510-AF140, this would be the correct one.
48510-09350 is for a 4wd AC w/o offroad package.
Probably but 48510-A9300 is the listing for 2wd.
I'm bumping this in the hopes that someone can answer the question--Does anyone know what is the actual difference between those shocks for the 2wd and the 4wd?
The Toyo parts page lists what looks to be a dozen different shocks--and it is insane!
What I have--original Tokiko blacks on the front of my 2003 2wd V6 Standard Cab
What I also have in hand are a decent pair of used fronts that have the 48510-AF140 Toyo/yellow blue Bilsteins that I got off a forum member years ago that I was finally going to install.
What kind of problems might I create for myself if I install them?
My guess is the difference is probably for weight. A 4wd truck is heavier so the shocks are probably valved slightly differently for that. If the shock you are going to put on is for a heavier truck then I would think it would ride a little stiffer, but would you even feel the difference?
