1 - 12 of 12 Posts
My new to me 04 Sequoia has developed a noise.
Its rotational
Seems to be from the rear axle
Does not seem to change with braking
Just started the last few days.
Wheel/hub bearing??
Don't feel anything with the noise. The speed with which the noise happens leads me to believe it's something wheel, brake, hub, or axle related. It doesn't seem fast enough to be driveshaft related.
I plan on putting it up on jackstands and pulling the wheels this weekend.
It does sound like a parking brake shoe IMO. Maybe not a bad idea to at least pull off the rear rotors and check
Check for bad U joint(s). I experienced similar noises in my 05 Tundra and it was a bad u joint. I pulled out the drive shaft and replaced the 3 ujoints with Moog brand and have had no problems for like 2 years.
Discussion Starter #8
Funny you should mention that. I tried to grease the front driveshaft the other day and I couldn't get the gun tip on the zerks. There wasn't enough clearance between the yokes.
That said, I don't think its driveshaft. It doesn't sound fast enough to coincide with the driveshaft rotating.
Bearings. I have had to replace a bearing (whole hub, unfortunately) on my 2005 Sequoia, 2010 Tundra, and my 2016 Tundra. The Sequoia noise drove me crazy for about a year trying to figure out what it was .
Discussion Starter #10
Today was brake day. New calipers, rotors, and pads all around.
Pulled the driver rear and some dusty bits of metal fell out, and found pads with no material left. Pulled the passenger rear and found...... nothing at all! The only thing in the was the cable!
So good news is the noise was definitely the parking brake. Bad news is I need some more parts to bring the parking brake back to operational status.
Glad to hear it wasn't bearings or something else expensive. Instead, you're going to learn about the most frustrating part of the Sequoia - installing the parking brake!
Discussion Starter #12
I really despise parking brakes located within the rear rotors. Seems like they're always a problem. My 23 year old Land Rover has the parking brake located on the rear of the transfercase and has worked flawlessly with zero maintenance. Wish I could say that for the rest of the truck! :ROFLMAO:
1 - 12 of 12 Posts
