1 - 15 of 15 Posts
I thought the serpentine belt was at 90,000 miles and the timing belt is at 100,000 miles?
Under normal driving conditions 90K or 72 months. This is for the 4.7. , It looks like the new 4.6 has a chain. I went about 115K before doing mine, just kept putting it off. Might as well do the water pump, tensioners and pulleys while it is torn down. I went ahead and let the dealership do mine, good thing I let them do it because the new waterpump they put in leaked after a few days. That would have been a ***** if I would have had to take everything back off!
How much did it cost you btw?
Just finished my timing belt replacement yesterday. I wanted to be thorough so I split the process into 2 days of about 5hrs each. The original belt looked fine w/o any cracks, but it did look a tiny bit stretched, as the belt cogs had a slight gap in the cam sprocket grooves. After 89k miles and 9yrs, it was due. I didn't replace the water pump or the tensioner, both had no evidence of any leaks. For ~$200, its a load off my mind. Here's what I used:
toyota t-belt: $50
GMB t-pulleys: $85
2gal toyota red: $53
2gal distilled water: $2
gatorback acc. belt: $27
8 NGK g-pwr plugs: $22
if the belt breaks will it damage the engine? I have 179k and the belt was last done at about 60k. I guess i should prob do it. Any idea what I should expect pricewise from a local shop, no toyota dealer within an hour of where I live.
· Super Moderator
Potentially yes, and catastrophically.
I suggest purchasing the timing belt kit from eBay vendor volkstoy ($238). It has the water pump and it is highly recommended that you replace it since you have the whole front of the engine off already.
Your local shop should do it (and stand by their work for a reasonable period of time) for anywhere from $300-$400. I would purchase 2-3 gallons of Toyota Red coolant from your dealer as well as the distilled water and supply it to the shop so that you know quality fluids are going in your system. :tu:
Good luck!
1 - 15 of 15 Posts
