I plan on installing a Kenwood DNX6960 soon and have been doing some research as to how to install it. I have located a Metra harness that will aloow me to gain access to power and ground but I would like to hook up the illumination wire so the unit will dim when I turn on the headlights. Where is the illumination wire located in a 2007 Tundra with the JBL? Which harness behind the radio is it in?
Okay, this may not make much sense to you until you have the wiring diagrams (which are on my other computer at work), but...
K4-2 (ILL+)
K4-20 (GND)
K4-12 (ILL-)
K4-20 (GND)
#2, #12, and #20 of your K4 plug which is one of the 20-pin plugs (K3 being the other). The K4 plug is a little fatter. I'll try to post the wiring diagram later this week if need be, but you may be able to track it down from a search.
Also, if you're interested I have the Metra double din dash kit and Scosche TA07SR adapter for sale in the classifieds.
