I have the 18" BXAT Diamond Finish Alloys, and I am looking at going with some 20" Alloys off of a 2009 Limited. Are the TPS sensors the same. I have heard that the steel wheels, which I don't have, use a 45 degree and the alloy wheels, 17" thru 20" use the 20 degree sensors. Is this correct?
You should be OK going from alloy to alloy the sensors are the same (at least on factory alloys).
You are correct...both use the same sensor.....
