Who makes toyota motors?
26124 Views 10 Replies 8 Participants Last post by  06TundraBoy
My friend asked me the other day who makes the motors for toyota. I was unsure and felt upset with myself for not being able to answer his question. because I have been a huge toyota fan my whole life. I have heard somewhere that Yamaha makes the motors, but I really couldnt see that happening.
1 - 11 of 11 Posts
Toyota either makes their own (Alabama and soo to be Tennessee) or they have a small independant engine manuf. make them. The 4.0Ls are made in AL.
toyota makes them. yamaha has assisted with the manufacturing of motors since the early 1980's, when needed.
Thanks guys so my information was somewhat correct:D
yup. also, if i am not mistaken, yamaha designed a few engines as well. possibly in the supra, or celica, 80's. cant remember. google will know
doesn't lexus build all the 4.7 motors in the tundra's ?
thanks anyway.
2007 Toyota Tundra Car Reviews - The Car Connection
The brilliant stuff
Two of the three engines available on the new Tundra are slightly tweaked versions of familiar engines installed in the outgoing Tundra. The third engine is new from crankcase to throttle body and probably the finest gasoline-fired V-8 ever installed in a pickup. And the world is full of great truck engines.
Base powerplant for the new Tundra is a version of Toyota's DOHC, 24-valve, aluminum block and heads, 4.0-liter V-6 which, in part thanks to VVT-I variable valve timing, is rated at 236 horsepower at 5200 rpm and a peak 266 pound-feet of torque at 4000 rpm. The entry level V-8 is Toyota's, DOHC, 32-valve, iron block, aluminum heads 4.7-liter V-8 which, in part thanks to VVT-I variable valve timing, is rated at 271 horsepower at 5400 rpm and a peak 313 pound-feet of torque at 3400 rpm. Both these engines are sweet natured in their power delivery, smooth in their operation and relatively efficient in their use of fuel. And both come lashed to a standard, perfectly mannered five-speed automatic transmission.
It's the biggest engine that impresses the most however. Branded as the iForce 5.7 to the public, it's known as the 3UR-FE within Toyota. Designed around the same structural architecture as the "1UR-FSE" 4.6-liter V-8 used in the Lexus LS 460 that was introduced last year and assembled at Toyota's plant in Huntsville, Alabama, this is Toyota's first aluminum block and aluminum head truck V-8. It's also the most American truck engine the company has built with the aluminum engine blocks and heads cast by Bodine Aluminum (owned by Toyota) in Troy, Missouri.
Like the Lexus 1UR-FSE, the 3UR-FE features cast-in iron cylinder liners, dual overhead cams, four valves over every cylinder and VVT-I variable valve timing on both the intake and exhaust valves. However while the Lexus engine uses direct fuel injection, the Tundra engine uses conventional fuel injection. But the big difference is, naturally, displacement. Both engines have 94-millimeter cylinder bores, but the Lexus engine's stroke is a short 83 millimeters while the Tundra engine's stroke is a long 102-millimeters. It's that long stroke that has the I-Force 5.7 making 401 pound-feet of peak torque at 3600 rpm while the LS 460's engine makes it's 367 pound-feet of peak torque at a dizzier 4100 rpm.
On top of all that throw in technologies like an "Acoustic Control Induction System" that uses butterfly valves inside the intake manifold that in two stages can adjust the length of the intake tract based on throttle position and engine speed, tubular stainless steel headers feeding an stainless exhaust system, and the result is a total of 381-horsepower. That makes the I-Force 5.7 the most powerful engine ever sold by Toyota in North America… car, truck or forklift. It beats the LS 460's 1UR-FSE by a whole horsepower.
There are a lot of excellent truck engines out there - the 315-horsepower, 5.3-liter Vortec V-8 in the Chevy Silverado, 317-horsepower, 5.6-liter Endurance V-8 in the Nissan Titan and the 345-horsepower, 5.7-liter HEMI V-8 in the Dodge Ram to name three - but the Tundra's I-Force 5.7 has them covered with more power, an utterly seamless delivery of that power, and eerily creamy smoothness that's almost spooky in its Lexus-ness. Then on top of that Toyota pushes the new engine's advantage by pairing it with a standard six-speed automatic transmission.
Using advanced manual counting technology (one-one thousand, two-one thousand, three-one thousand) during the press introduction of the new Tundra, a two-wheel-drive 5.7-equipped Regular Cab Short Bed ripped from 0 to 60 in just about six seconds flat. Except for high-performance sport trucks like the Ford SVT Lightning and Dodge Ram SRT-10, the new Tundra is likely the quickest factory pickup ever built. And unlike the SRT-10 or Lightning, it retains all the usefulness a truck should have while being blisteringly quick.
The combination of the I-Force 5.7 and the six-speed automatic transmission is simply… brilliant.
Not positive but I've heard that Suzuki makes the corolla engine
Yamaha designed the heads on the 5M-GE/6M-GE (same head, 6M uses 7M block wich is a .2L increase), 7M-GE/7M-GTE, 1JZ-GE/1JZ-GTE, 2JZ-GE/2JZ-GTE motors wich came in the Lexus SC300/Toyota Soarer, Lexus GS300/Toyota Aristo, Lexus IS300/Toyota Altezza, Toyota Cressida/Cresta/Chaser/MarkII and Toyota Supra.
All the other engines such as for example:
1UZ-FE, 2UZ-FE, 3UZ-fe are designed by Toyota.
The G series engines by Toyota are more performace orientated. The 2JZ-GTE itself can handle a whopping +800hp on the stock internals without blowing up.
Toyota, of course. Otherwise, it would not be a Toyota. Ford makes Ford motors, Chevy makes Chevy motors and Dodge makes Dodge motors.
Cant forget the famous 2ZZ-GE!!
Brilliant engine. Just brilliant.
1 - 11 of 11 Posts
