Will i need a longer brake line if i install new TC UCA and ICON CO set at + 1.5 inch higher than stock height?
I ask because the combination of 2 things might the brake lines limit the suspension travel.
A) TC claims additional wheel travel with their UCA.
B) plus setting my new ICON coilovers to + 1.5 inch higher than stock.
All this for a 2010 4x4 crewmax.
My brother has this set up on his 02' with the extended travel Icon's and he has no problem with brake lines. His are cranked to about 3inches of lift also. I'm sure you will be fine, there are alot of members with the 2nd gen Tundra's running this lift too and I have never heard anything about brake lines getting in the way. TC or Icon would have said something if it did. If you are going long travel, then yes!
Adding 3" of droop to a new style Tundra is different than running more preload on an older Tundra. ICON should know.
