will a 2 1/2" billet spacer from an 04-07 f150 or titan work on a 2000 tundra? is the spacer the same size as a tundra? found a set for cheap....checking into it
need input please
need input please
In general I would guess that it would not, unless they have the same coil and damper inner and outer diameters, and possibly the same mounting bolt pattern would be required. Also if the suspension geometry is at all different (length of control arms, etc), a 2.5" spacer for those trucks will not give 2.5" on a Tundra.will a 2 1/2" billet spacer from an 04-07 f150 or titan work on a 2000 tundra? is the spacer the same size as a tundra? found a set for cheap....checking into it
need input please
