Only driver’s side window working with inside control switches. Hatch operates with key.
If you had your battery replaced/disconnected the driver's main switches sometimes won't control the other windows. Go to each window and fully lower/raise the window using each window's individual switch. This should "reprogram" the system so your driver's controls will operate all four windows.
