I'm trying to find the Door Lock (White wire) door lock (red wire) and alarm (black wire) in the drivers kick panel area. I have no idea which plug/module it is. I'm trying to install a Keyless entry pad (like a Ford) Any help would be great. Thanks
Mark
I have a picture somewhere...
the plug on the right of that pic is the bottom in the kick... it has the red and white wire you need... assuming you don't have the factory alarm activated, you don't need the black wire... if it is activated, you need:
Arm with Lock (-) Lt. Blue - DKP
Disarm with Unlock (-) Pink - DKP
which are the small wires in the next plug up... you can always test these by using a jumper wire to tap to ground
