i have an extra toggle switch in my truck thats not in use, and my license plate light wiring is cut, so i figured i would experiment but trying to hook the toggle switch to the license plate light. im not a real expert in electrical so whats the process
Why don't you just repair the existing license plate wiring? If you want to run it on the extra switch, you'll have to run a power wire to the switch, a wire from the switch to the light, and find a good spot to ground the lights. If the switch has an indicator light in it, you'll need to ground the switch so it lights up when turned on.
