1 - 20 of 54 Posts
i live in upper michigan and have had 8 trucks in the last 18 yrs. i love my 2008 sb 4wd reg cab 5.7 tundra. nicest and hottest truck i've had. BUT it's the worse 4 wd i've owned. won't lock and in the mud and snow in the U.P. it's been a huge disapointment. everthing else beats all comers that i'm surprised that no one has challenged them to fix this. it's never a good thing when your pulled out by a chevy that is so inferior in all other aspects. not the tires i spent 1200 bucks on off road michelins.
My 4WD works great, even with stock rubber. Maybe its your tires or driving style?
must be you or your truck...spent a few years in washington and pulled out lots of stuck trucks through 2 feet of snow with no issues, had a real snowy season in NJ this past winter with no issues and go play in the mud quite frequently. I have never been stuck and always pull through just fine. i mean i'm actually impressed with how my truck handles in the mud and snow.
i've grown up in the u.p. you learn how to drive in the snow to survive. in my farm field this 4 wd won't lock and it works against itselfe. even my under powered ford 150 that was a puss with the horse trailer behind it had a much better 4 wd in the tough conditions on heavy snow or mud.
i have plenty experience with driving in the snow, was stationed in alaska for 6 years as well and wife is from MI. It really must be something with your truck, my truck locks up and flys through the snow like nothing.
hi way handling with the all traction controlls is so impressive. i'm talking about when your pulling or loaded in real heavy mud or snow.
Prior 4X4 vehicles include a GMC S-15, (mid 80's) Ford F-150 ('05) Dodge Ram 2500 ('99) Nissan Pathfinder ('94). . . I find this Tundra every bit as good in 4WD mode as any of those, maybe better, certainly not worse. In my own snow, mud, dirt, and sand driving experience.
He has a point: Mine get´s stuck on 4hi on my slightly sloped driveway in heavy snow, but it´ll pull through just fine in 4lo.
So that might be the solution - let us know as that works for you.
i have no traction controls in 4wd. everything turns off, is something different with the 2008's and up?
My pleasure by the way...thank you
am i wrong 4wheel drive is 4 wheel drive its always 4wd when you hit that switch???? How big of the tires did the chevy have? what was its load in the trunk? alot of factors...but I have a hard time believing 4 wheel drive wont let you drive in snow??? is your tundra lowered or something?
What'za "off-road Michelin"? Didn't even know they made off-road tires.
and uh, don't you need lockers for all wheels to lock? Without lockers no 4wd will lock all four wheels.
Worst, not worse....
DC area got hit with 2 big snow storms this winter. First was almost 2 feet of snow, second was 3 feet with higher drifts. My Tundra with the All Terrain T/A's got anywhere and everywhere I tried. At work I drove a couple different Chevy and Ford 4wd pickups. The Tundra was just as capable as the other trucks with true limited slip. It took me a little while to get used to the Toyota system. I learned, at least the few times I got stuck, that if you have higher rpms in 4wd, you can get all 4 wheels to spin. I assume that the ALSD system kicks in at higher rpms.
I think our 4runner and our '98 Expdition were better vehicles in the snow, BUT, I would be hard pressed to find another that beats it out by that much. The 4runner and Expdition did great because of the SUV factor.
With my balding KOs, I can get anywhere in about a foot of snow pretty easily. Some wheelspin and she'll get goin'!
-rockstate
Rear differential = open
Front differential when engaging 4wd = locked (hence why you don't use 4wd on dry pavement)
So when you're in 4wd you are putting power to 3 wheels, possibly 4 if A-LSD works in 4wd.
1 - 20 of 54 Posts
