Like the title says, if I need to change a cracked manifold might as well go big or go home!
Much appreciated if you see anything!
Moderator
Discussion Starter #4
Indeed, thanks for the help all.
So are the TRD headers 1.) Long tube and 2.) Carb legal?
Keep on getting different opinions. Need to verify before I pull the trigger on those, otherwise Im going with Doug Thorleys.
Moderator
Yeah TRD version is CARB legal.
As far as Long-tubes... I guess if you viewing them as longer than other tubes...."long tubes"
The TRD Primaries are only 1.5" in diameter, and the collector isn't very large at all. I don't 100% remember the diameter but I believe it steps down to 2" and then the adapter goes into the 1-7/8" piping for the Converters. They're still pretty constricted.
I'd say you're better off getting the Doug Thorley's
Then prepping for a TRD supercharger.
