does anyone know the location of the yaw sensor in a 2005 tundra dc 4x4? i have searched and can only find it for 2007 and up. i pulled the whole center console out and it is not anywhere to be found. after i installed the camburg coilovers/UCA's and blocks, the VSC was kicking in often. after installing the "Total Chaos Poly Steering Rack Bushing Kit" from wheeler's, it just got out of hand! i cant stand it anymore! if i can simply find the sensor, im going to try spacing it up in the rear (to simulate the factory stance). thank you in advance.
thanks Bestaley for your response. I have read another post (i think it was about amplifier installation) that they thought it was under the passenger seat too. nobody seems to be certain about it though. I am just nervous that it might be an airbag sensor (yellow wire loom).
Mech. Engr. / Mechanic
Here is from the 06 manual. There are several sensors under the passenger seat. Deceleration, Yaw, seat belt, etc.
