41 - 60 of 2031 Posts
Re: post pictures of your double cab tundra 2005-2006
06 DC 2WD
Chrome Nerf Bars
XSP Package
Enkei Wheels
Pirelli Scorpion Zero Tires 295/45/20
K&N Air Filter
Planning on doing a lot more... $$$$$$
Re: post pictures of your crew cab tundra 2005-2006
It is lifted 2 3/4" in the front. I will be adding AAL later this week, should add 1 to 1 1/2 in the back. Not sure on tires.. I really don't know what the max size that will fit with this amount of lift. Any ideas?
Crash_OK, you have pretty much the same setup as me - I just ordered the Bilstein 5100s front and rear, TC diff drop, and rear AAL from Offroadwarehouse.com. I'm also running the 17" Limited wheels like you, and based on my research (and help from other members) I ordered billet spacers from ORW for $90 and plan to run 285/70-17 tires (probably Wrangler SilentArmor or Revo A/Ts). From what I have been told this setup will work with *minor* rubbing in the rear on full-lock turns when the shock is compressed.
The stance looks really good on your truck, but the tires definitely need to be "pumped up" to get a better look. Still looks like a giant red skateboard, but at least a 4wd skateboard. :D
here's my 06. My money is currently going to my atv, 2007 suzuki king quad 700. I plan to get new wheels/tires for the atv, then lift/wheels/tires for the truck.
Discussion Starter #47
im liking the dark charcoal ones, i want to go with black wheels on mine!
Here's a couple on the way back from a race in Plaster City CA.
no rub? what size tires, wheels, backspacing, offset yada yada? if you know
Bitchin tow set up man. You would'nt happen to need a airbag set up for that would you?
You tryin to sell one? I do not need it now because I never hit the stops but want to drop the back and will probably need it then. Let me know
Nice setup. There is simply not a better color than Spectra Mica Blue IMO.
Thanks. I had a hard time getting this color and it was well worth the work. I love this color and do not see to many of them on the street.
Who do you go see at the races? I have probably seen you around Temecula. Your truck looks familiar. I am from around there as well.
a couple of shots of mine
Here is my 2004 DC and its Mods...
Here is mine
My truck has King Coilovers, Total Chaos Diff Drop, Bilstein 5100's in the rear.
Rims are Pro-comp 1069's 16x8 with 4in backspacing and 285/75/16 toyos.
Discussion Starter #59
any rubbing? and what heigh are you set at right now? how does the ride feel, softer harder? and is the Diff drop required?
2005, lowered 1.5" in rear. Lots of mods. The stereo projects never end................:rolleyes:
