Automatic Door locking on 05 Tacoma Double cab? (TBM)
1 reading
4.6K views 19 replies 10 participants last post by  rrllarry
#1 ·
I did the search thing and found nada so I figured I'd ask. I want to enable Automatic Door locking (and unlocking) on my 05 Tacoma TRD Double cab. Is this even an option on the 05 Taco.
Thanx!!!
#2 ·
Thanx!!!
Don't know about the Tacoma yet but my Sienna has this feature. It was not part of the factory system but was part of the RS3200 alarm system. I had a problem with it at first not doing what it was supposed to however a trip to the dealer and they reprogrammed it for me. Aparently there were several program modes available.
#8 ·
Thanx!!!
Not a function with the wireless door lock control. See attached
#10 ·
p8ntballa04 said:
He wants it to lock automatically when he is driving. Not if he doesn't open the door within 30 secs.
My last Toyota (Celica) did that by default, using the Toyota OEM security system - you could turn that on or off but it was kind of hard to find the procedure - I think I saw it somewhere in the TS knowledge base.
#11 ·
As I posted earlier, not an available function with the keyless entry only. Is a programmable function of the RS3200 Plus system, which is an add on option to the '05 Tacoma.
#12 ·
how do i know if i have the RS3200 or not? and if i have it, how do you program it? take it to the dealer?
thanks
#14 ·
thanks
If you have the factory keyless entry option in your '05, you do not have a RS3200. If you would like me to confirm this post or PM me the FCC # from the fob. The factory keyless is a body ecu based system. Vehicles with the factory keyless can be upgraded to a RS3200 Plus system. Programming instructions are available in the Knowledgebase in the thread HOW TO: Programming the RS3200 system
#16 ·
blacktac said:
so is the upgrade a hardware upgrade or just program software/program upgrade? sorry im a bit confused since the dealer never offered me to upgrade my system
Hardware Tacoma TVIP V5 (RS3200 Plus), part number 08586-04840
Includes:
1 Wire Harness
1 Security ECU
1 GBS ECU
1 Status Monitor
1 Hardware Bag
Note: Tacoma with Remote keyless Entry, only. Must not be installed in vehicles with factory TDS.
Installation instructions available in the Knowledgebase
#17 ·
Mine locks when the engine is turned on
I don't have the RS3200 system, but do have the keyless entry on my 2005 Tacoma. My doors automatically lock when I start the engine & unlock when I turn the engine off.
#18 ·
I wish mine would do that. I have the factory keyless entry. I saw a post once that you have the factory alarm wired in the truck but just have to unplug a wire to make it work. I tried to find the wire but was unsuccessful. If anyone can help out please post it here.
#19 ·
That is not the case on a '05 Tacoma, but would be on vehicles that have the RS3200 system as the ECU to control the keyless entry. The whold procedure is documented in the Knowledgebase.
