Broken license plate screw removal - rear
436 views 2 replies 2 participants last post by  SilverSequoia123
#1 ·
Snapped the head off of a license plate screw on the rear of my truck when I got new tags. Wondering what might be the easiest way to get it out? Any thoughts? I’ve never had much luck with screw extractor tools. The previous owner changed the rear hatch assembly so I’ve never taken the rear door apart. Could I get to the other end of the screw from inside the door by removing the back panel?
#2 ·
Question is why did it snap. If it wasnt crossthreaded then it should be somewhat easier to get out. If you pull the hatch cover and can see the end of the bolt you could be able to just grab the end with some pliers or vice grips and turn it out.
If its crossthreaded then you're probably into a drill and extract.
#3 ·
Recently moved and got new tags. Installing the screw back in I must have cross threaded it which is weird because I was really trying to be careful not to do that. It was going in smoothly until about halfway down when it started to bind a little. I gave it just a hair of pressure and the screw snapped. Still have not had any luck getting it out. Been busy, going to give it another shot this weekend.
