I have a second-hand Highlander 02 Ltd, V6 4WD.
My first question is if this highlander model requires timing belt change in certain milage? if yes, after how much miles I need to replace the timing belt? What would be a reasonal cost to replace a timing belt for 02 Highlander?
Second question, I recently had the Engine Check light and VSC light both come up, what kind of problem is that and how may I fix them?
Thanks for any possible helps!
:ts:
:ts:
