Mike,
Raybestos makes top quality NEW master cylinders.
Only buy new units, rebuild units never last long........:typing:
Here is why, rubber seal seldom fail in master cylinders and even wheel cylinders. Believe it or not the rubber lip seals are the most resilient part of a brake system.
Master cylinders and wheel cylinders usually fail from pitting of the cylinder bore. Rebuilt units are honed to remove these but many times small pits are left and or the bore is too over sized to maintain a good safe
seal to the lip seal. Also some remanufactures use the old pistons over which also can become pitted. These poor quality controls used to keep the prices down make for a dangerous part.
Many rebuilt masters don't work off the shelf. If they do work, your driving with a time bomb, your brakes could fail at anytime.
I bring this all up as a warning, my belief rebuilt master cylinder should be outlawed.
Just make sure you always buy new!
Mike
