I have installed a new aftermarket amp with the OEM HU under the passenger seat. While I was doing this, I decided to buy a power outlet at PEP Boys. This is simply an aftermarket power outlet that is suppose to go under your dash, but I installed it behind the drink holders in the center of the vertical black space right below the handle where you open up the console. I hooked this up to the power lead to the amp, this way I have a power outlet that is constantly 'hot'. Installation is simple - you just drill a small hole in the center of the where you want to install the outlet. This hole will be drilled through both the removable cup holder and the inside of the center console. You then remove the cup holder and drill a 1" hole with a 1" wood bit. Drill another 1" hole in the center console. I had to take a box cutter to enlarge the hole slightly in the cupholder piece due to the way the power outlet installs. When you are done with the holes, snap the cup holder piece back in and install the power outlet in the hole and connect the power and ground wires. I am going to use this for my cell phone charger.
I am using the bolts that secure the center console as my main ground. Does anybody else use this as a ground? I just got everything hooked up today and have MAJOR engine noise. I am going speaker level (front right and left) to my EQ's speaker level inputs then RCA's out to the amp, then to new speakers (all 4). I ran 8 gauge (monster brand) from the battery to the amp and I am also powering my EQ with this. I'm using the ac switched from the blue wire behind the HU. Of course, it sounds great when the truck isn't running, but when I turn the truck on it's bad! Is there an obvious ground error? I guess I will go get a noise filter and start diagonstics with that. Any ideas?
Hope you find the power outlet mod helpful!
Chris
Chris
