61 - 65 of 65 Posts
I have 12 interior lights out, mode lights on upper panel, tilt and slide- sunroof, lock, window lockout, manual height for the air suspension, a/c 115 lightr , toyota security, seat set, rsca off, rear fan, right heater, mirror and all the lights on the back of the center console. I have been searching for the bulb or led replacement numbers of these switches. Are the bulbs replaceable in these units? 2005 Sequoia
Don’t know that the sunroof switches are supposed to light. Will have to investigate. Don’t know about the window lock out either. The height adjustment button has a place for a bulb but doesnt seem to work. Been looking into that one. 115v definitely has a replaceable bulb. Don’t have security option. Rsca doesn’t light up. Rear fan does. Right heater? Seat heaters light up. Mirror controls do not. I just replaced that switch with new and no light to be found.
Back center control? You mean rear climate control? It also lights up. All the center console switches and panels will come out with a flat head screw driver and careful prying. Haven’t done overhead panel ones yet. Not sure about dash buttons left of the steering wheel either.
seat heater lights- use a plastic trim tool to pop the switch out from the console, unplug the connector (be careful, it's short and will want to fall back into the hole). on the side of the switch, you'll see a little silver square, like aluminum foil. the bulb is under there, its a neo3 from superbrightleds.for the ignition switch bulb, see below.
61 - 65 of 65 Posts
