This is my proof that the tundra 5.7 liter has a timing belt
Great info file, where did you get it? off the net or some other source? I would like to see all the files on this engine.And this is my proof that it is using a chain. :tu:
Jochen
The 5.7 uses a chain, period. NO IFS OR BUTS, its a chain!
I heard the Ford F150 uses a timing rope.![]()
The chain on the 1FZFE generally last the life of the engine (300k+ mi), no noticeable noise. The 3URFE (5.7l) has two timing chains, one for each bank of cylinders, I bet they will do fine and last a very long time.When that chain stretches and wears out (all of them do) you'll wish you had a timing belt. The guides wear out. The chain tensioners go bad. Long chains in overhead cam V8's stretch like mad. They slap around like crazy after awhile. Not now............5 years from now.
Chains were great when they were a foot long and drove camshafts in pushrod engines. These newer 5 foot long chains in overhead cam engines don't last like shorter chains did. When they stretch (all of them do) you lose 10 or 15 degrees of cam timing. Belts don't stretch. Belts don't fail if you replace them at the proper intervals. You can replace a 4.7 timing belt in an afternoon. Not bad for ~ 100k miles of service that you get from a belt.
Give me a belt any day.
I respect your opinion, but the jury is still out on the 5.7. It's too new. Timing chains on a 22r Toyota were usually "clapped out" at around 150k. The guides would break. The chain would slap around and eat a hole in the timing cover coolant passage if you ignored the slapping chain for long.The chain on the 1FZFE generally last the life of the engine (300k+ mi), no noticeable noise. The 3URFE (5.7l) has two timing chains, one for each bank of cylinders, I bet they will do fine and last a very long time.
This is not true. Belts do strech, especially if it takes many years to reach the 90K mile interval.Belts don't stretch.
Just curious where you are getting your information from. Belts do stretch, and belts can also snap or warp.I respect your opinion, but the jury is still out on the 5.7. It's too new. Timing chains on a 22r Toyota were usually "clapped out" at around 150k. The guides would break. The chain would slap around and eat a hole in the timing cover coolant passage if you ignored the slapping chain for long.
Then there's the loss of performance issue with a stretched, but not necessarily failed timing chain. A glass reinforced belt never stretches more than a degree or two. A timing chain on its last legs will be stretched/worn so that the cam timing is 15 degrees or more retarded from factory specs.
Some of you trade trucks every 3 years or sooner so you couldn't care less.
I keep my stuff 20 years or longer.
I'm not knocking you at all. I'm just saying.........
To the average motoring public a truck due for a timing chain or a timing belt is ancient history. A slick talkin' salesman dude would rather trade you out of the truck as you show up for your 90k timing belt change at the stealership.:td:
I do not believe this correlates to timing chains/belts.a side note here......
on motorcycles,...you have to adjust your chain every 100-1000 miles depending on riding style,.... then replace at 5-20k miles depending on the care.
harley's have belts that need changing every 30000 mile or so and do not need the adjustment as they dont stretch as much as chains do..
just something to think about.
its all comprimise,...my race bike i adjust about every 200 miles and replace every 5k...
my street bike i've had bikes with 30K miles with the original chain.
