Antenna question.
2001 Toyota Sequoia antenna. This is the position it has been for a year now. This forum is the best resource to find answers.
Anyone have a solution?
I did search on YouTube. No satisfactory answer. Same labor to either replace this antenna, or to completely remove it and install a fixed "screw in" antenna.
I should mention, in a past life, we drove a Ford Taurus in California. It had this type of antenna. When it failed and needed to be replaced, a friend who worked at a dealership, spent 10 minutes after work, pulled out the old antennae, and with me holding the rocker switch on... was able to feed the antenna in and voila.... was perfect.
Toyota Sequoia first generation, the antenna motor activates when initially turning the ignition key on to start. a short a mount of time sufficeint to raise the mast, and the motor then stops.... whrr whrr whrr whrr.... the motor is willing. but antenna? not so much.
