Fuel Pressure
15K views 2 replies 2 participants last post by  AJHOYT
#1 ·
I have a 2005 Tundra with the 4.7 and it has 100,000 miles. It has two DTC's P0172 and P0175. I have tested the O2 sensors and all four are functioning correctly within specs. I don't really think it is one of those anyway since the truck started running rich on the the right and left bank at the same time, so I am looking for something that is common to both, but I'm still checking everything to make sure nothing is missed. There are no mechanical problems, the engine runs fine. I and going to check for a stuck open injector in the morning by pulling the plugs and checking them. I just cleaned the MAF sensor, and I want to check the fuel pressure but I don't know how to do that on this truck. How do I check the fuel pressure and what should it be? Thanks,
#2 ·
I checked the trouble codes and here is a list associated with those codes:
You can find the complete list here:
http://www.tundrasolutions.com/forums/1gen-tundra/123989-diy-do-it-yourself-user-knowledgebase/
Scroll down to Other Useful Knowledge and Tundra Trouble Codes.
Injector leak, blockage
  • Mass air flow meter
  • Engine coolant temp. sensor
  • Ignition system
  • Fuel pressure
  • Gas leak in exhaust system
  • Open or short in oxygen sensor (bank 1 sensor 1, 2) circuit
  • Oxygen sensor (bank 1 sensor 1, 2)
  • ECM
The MAF is easy to clean:
Tundra Fuel Economy: MAF Sensor and Throttle Body Cleaning
Tundra Fuel Economy: Cleaning the MAF and Throttle Body
I would work down the list and hopefully you get it solved before you get to ECM. Good luck and let us know what you find out.
#3 ·
Turns out the ground for the injectors was corroded pretty badly. I cleaned the ground and the long term fuel trim started climbing back toward 0, it's still around -3 but still climbing. The air/fuel ratio sensors are reading just under 3.3 volts, and the O2 sensors are reading around .6 volts. It also corrected the failure to shift into overdrive problem I was having also. Thanks for your help Highway Lizard.
