4.5" Tuff Country with Adjustable Bilstein 5100s?
1.5K views 4 replies 4 participants last post by  Remmy700P
#1 ·
I'm sure this question has be asked before but i can't find anything on it. I'm currently running a 3" spacer up front with nothing in the rear and 33s on 20x10s. I was looking into the Tuff Country 4.5" suspension lift but i was wondering if you can run that with the bilsteins or the rancho quick lift because i want a little bit more in the front and be able to clear 35s. Please let me know. Thanks :)
#4 ·
bad idea and can be unsafe, if you want a 4.5 inch lift stick with the parts you get from tuff country. if you want more lift, ie 6 in is the next size up, get the 6 in lift kits. if i was going to be cutting anything off the bottom of the frame for a lift i would go with the 6 since you can easily clear 35s with that and its more lift.
