41 - 60 of 65 Posts
When I decided I didn't like the look of the LEDs in the center cluster, I went to the dealer and was able to find out that the bulb part number is 90011-03009. I bought enough to change all of them in the center cluster and it looks great.
The only bulbs I have left to worry about are on the window switches. I pulled the whole assembely apart today, and couldn't find a bulb. My guess is the whole switch assembly will have to be replaced. If that is the case, I think I can live with it.
Another update. None of the lights were working on the rear seat heater control cluster either. I pulled it apart tonight. There are three bulbs identical to the ones on the front center cluster, Toyota p/n 90011-03009.
Can anyone tell me if the RSCA switch to the left of the steering wheel lights up? That's the only switch I have left that isn't lit that I think should be.
For the Glove Box= High Intensity 74. 74-xHP: Wedge Base LED Bulb. 74-WHP: Cool White...did you have issues with the LED replacement bulb fitting in the housing? If so, what did you do to get it to fit? On my Sequoia the LED is too large to large to fit in the housing to make electrical contact and stay in the housing
Hi Bojo - What is an RSCA switch? My Sequoia has three switches to the left of the steering wheel. They are the instrument cluster dimmer control, the rear hatch window switch, and the 115 volt AC power switch. Of these three switches, only the 115 volt AC power switch lights up. I'm not sure if the other two are burned out or even how to remove the sub panel that these three switches are mounted in.
Also, I was wondering if are all the stock bulbs you replaced white, green or a mixture of the two?
And what color was the stock bulbs you purchased from the Toyota dealer? - Thanks
Did anyone ever answer this? Are LED's dimmable? for those of you that have them. Also, could you direct me to the complete list of replacement LED's (if there is one) that would work for 2001 Seq? I've seen fractured posts all over, but not a comprehensive all inclusive list that would match OEM, so you only have to pay shipping once. IS there such a thing? Thanks a bunch!
No I haven't answered it.
Yes they are dimmable.
Yes there is a complete list. See 2 posts before you on page 3. It isn't OEM, but if your going to tear it all apart, may as well put LED. Cheaper and brighter.
Remember the 10
I recently swapped some of my oem bulbs for these. Specifically, this is only for the front map lights, the door panel lights, the passenger dome light and reading lights, and the rear cargo light. Everything fit perfectly. Makes a dramatic difference. I've had them in about a month. So far, so good. This is exactly what I ordered:
https://www.amazon.com/gp/product/B00HE6CI58/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B00NTOJU28/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B00OH0S5Y2/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
I have an '05 Limited.
The "fan REAR" button to the right of the fan speed dial and below the passenger airbag indicator DOES light up.
The dimmer knob to the left of steering column does NOT light up on mine, so I can't say whether it's supposed to or not. The RSCA OFF and the center diff lock buttons also don't light up on mine, but it looks like they might be capable of being lit.
Taiko,
Can you share your successful LED light replacement experiences for Sequoia? My 2004 needs some light bulbs replacement. Was LED a better choice in terms of life?
Thanks
The new to me '03 I bought had the interior and door lights switched to LED and it is so nice. So much brighter. I can take a shot of the lights and how they differ since they didn't swap the rear bulb in the cargo area. Pics forthcoming. I have some dash and interior bulbs to replace to illuminate all buttons that are supposed to be lit up.
Dan
A lot of my dash and interior bulbs are burned out (2005 Sequoia limited) and I'm wondering about parts required and best techniques for accessing the bulbs.
-Driver's side heated seat indicator light is burned out
-no lights behind any of the 4x4 controls (diff lock, 4x4 on/off)
-no lights behind the mirror adjustment (mirror angle adjust, fold down, etc).
I know that there should be a light in the heated seat switch, but the 4x4 controls and mirror adjustments are completely black and I'm not sure if they even have bulbs behind them. Thanks for any info!
I have 12 interior lights out, mode lights on upper panel, tilt and slide- sunroof, lock, window lockout, manual height for the air suspension, a/c 115 lightr , toyota security, seat set, rsca off, rear fan, right heater, mirror and all the lights on the back of the center console. I have been searching for the bulb or led replacement numbers of these switches. Are the bulbs replaceable in these units? 2005 Sequoia
41 - 60 of 65 Posts
