Thank goodness for this web site and sites like it!!!
Mike Erdman Toyota on Merritt Island in Florida told me I would need a new rear window motor at $300 plus labor. I decided I would live with window not working as I very rarely used it anyway. After reading various posts on this subject and finding the following Toyota Service Bulletin (
http://www.justanswer.com/uploads/skyvisions/2008-02-25_151840_01_seq.pdf) I went home and removed the metal stopper as outlined on item 14 of the bulletin. I also "tapped" the motor for good measure and disconnected and reconnected wiring harness. Nothing happened until I re-secured the metal panel back to the door and then the window started working. I suspect it was the metal stopper that was the solution and I also suspect the circuit might be grounded by the metal panel and that is why it only started working after I got it all back in place. Repair only took about 30 mins and it cost ZERO!!!
I have fixed several items on my 2002 Sequoia myself thanks to this site... For example; the rear door handle that broke, blown front door speakers and the bulb for the "drive" signal on the dash. These are all items that appear to be common issues on this car and things that can be repaired for a fraction of the cost from a dealer if you are somewhat "handy" and prepared to fix yourself.
Thanks Tundra Solutions!!!
