Breaking News From Sway-A-Way, Inc
1 reading
3.3K views 5 replies 5 participants last post by  T23
#1 ·
[True Off-Road Racing Performance, Period!
From the leading manufacturer of high performance suspension technology, Sway-A-Way proudly introduces their newly re-designed RaceRunner bolt in performance coil-overs for Toyota trucks. RaceRunner Toyota Coilover Shocks come exclusively from the RaceRunner high performance off-road shock line, which has a long history of winning technology and success in the competitive off-road racing market. These kits feature both 2.0” & 2.5” diameter RaceRunner Coil-over Shocks. The 2.0” is ideal for those of you who prefer a smooth street ride with the ability to play in the dirt comfortably, and the 2.5” features 50% more oil capacity to keep the shock cooler for the hardcore off-road enthusiast who pushes their suspension to the limits on every adventure. Sway-A-Way has been the leading manufacturer of "True Bolt In Performance Coil-Overs" for Toyota's since 2000 and many other companies have followed suit. With new technology, a higher level of manufacturing excellence and wider scope of applications, RaceRunner Shocks can be found on more performance vehicles than ever before. For over 30 years the Sway-A-Way name has been a leader in off-road suspension technology.
Key Features:
-6061T6 Billet Upper Mount Plate
-Nitrogen Charged To 200Psi
-0-3" Adjustable Lift
-Internal Floating Piston Which Seperates Oil & Nitrogen To Prevent Cavitation & Fading
-High Tensile Chrome Silicone Spring, Prestressed And Shot-Peened To Preven Sagging
-Beautiful Electroless Nickel Finish
-"Real" Hydraulic Full Extension Damper
-7/8" Hard Chromed Shaft
-Urethane Shaft Bumper
-All Components Are CNC Machined In House From 7075T6 & 6061T6 Aircraft Alloy
- 5/8" PTFE Teflon Lined Steel Spherical Bearing
Applications:
2.0" Dia. 96-04 Tacoma, 00-05 Tundra, 96-02 4-Runner, 00-05 Sequoia
2.0" Dia. 2005 Tacoma, 03-Current 4-Runner
2.5" Dia. 05 Tacoma, Which Includes A Stock Replacement Swaybar
2.5" Dia. 96-04 Tacoma, 00-05 Tundra, 96-02 4-Runner, 00-05 Sequoia
Pricing:
2.0" Dia. $749.99 per set (Includes a spanner wrench)
2.5" Dia. $899.99 per set (Includes a spanner wrench)
2.5" Dia. 05 Tacoma $949.99 per set (Includes a swaybar and spanner wrench)
Please feel free to PM or email me ryan@swayaway.com with any questions. Once again Thank You for your interest in RaceRunner Shocks. All product is available, please contact RaceRunner Authorized Dealers to purchase product.
#2 ·
what I want to know is why the 2.5" is cranked all the way and the coils wrap a full seven times making it shorter over there 2.0", while the 2.0" is 9 coils and not cranked all the way, doesn't look right. And yeah I know less coils on the 2.5" to give a not so harsh ride since its stiffer.
#4 ·
SAW Coil Tools
From the leading manufacturer of high performance suspension technology, Sway-A-Way proudly introduces their newly re-designed RaceRunner bolt in performance coil-overs for Toyota trucks. RaceRunner Toyota Coilover Shocks come exclusivel......................., 00-05 Tundra, 96-02 4-Runner, 00-05 Sequoia
Pricing:
Question:
How do you install / remove these yourself? I have a older pair I purchased and was able to install them a few years back using the old motorcylce tie down strap method and a floor jack. Back then I had the advantage of truck lift which greatly helped in the matter.
I realized I made BIG mistake and installed the right side with the valve facing to far back to be able to fill / check the nitrogen level. So I tried to use several different compressors to get them off. No luck. I would like to own a coil compressor so I can take these things off someday in the future in case they need a rebuild etc. Where can I get one that works with the RR SAW?
Also, do you sell guages to check the nitrogen level?
Lastly, my spanner wrench tip bent at a 45 degree angle making it worthless. Where can I get another one of those?
Any info would be greatly appreciated.
Thanks,
T23
#5 ·
T23 said:
Question:
Thanks,
T23
Easiest thing to do is to disconnect the sway bar link and lower ball joint. Then the coilover will fall out.
When you go to charge these shocks, they should be fully extended.
Autozone rents out compressors, compatible with 2.5" shocks.
Gauges can be purchased to measure Nitrogen. I believe Baja Concepts sells them and spanner wrenches. I bought my spanner wrench from King Shocks. ORW has em online as well. Mind you these are the nice thick billet alluminum, not the little thin wrenches.
#6 ·
No Autozone around here. Who makes the compressor? I will check oaut Baja Concepts and ORW.
If you drop the shocks out are they easy to put back in the same way?
Thanks.
