So, I started the install of my Donahoe coilovers, TC diff spacers, rack bushings and Bilstein 5100 rear shocks. As they say, nothing is easy; the following is my day 1 experience which I thought would be valuable for anyone who is planning on this type of setup. I know this install should only take a few hours but read on and learn what happened. There is nothing bad, but there are some good lessons learned so far.
1st. Removing the factory struts. The top comes out easy enough and the bottom bolt is just a little tricky. The lower strut bolt installs from the back, the problem with this is that when you put the truck on a lift, the drive shaft droops at an angle so that the bolt does not clear the shaft. A little pressure lifting the strut from between the lower strut mount and lower control arm gives you just enough space to slide the bolt out. Not to bad.
2nd. Installing the new coil over. Let me just say this, save your self some time and just pop the upper control arm ball joint. The reason why is the following. When you install the Donahoes, you have to push the lower control arm down (with a crow bar) to fit the slightly longer strut. This steepens the angle of the drive shaft that is already in the way. I learned this on the driver side; I will tell you what this lead to in a minute. On the passenger side, I popped the upper ball joint which allowed the steering spindle to tilt out just enough to counter the downward angle of the drive shaft. Now, with just a little persuasion, the lower strut bolt slid in from behind. It took about 15 minutes to do the passenger side. Now let me tell you what happened to the driver side.
Remember, this is the side I started on and was where I learned the lesson to just pop the ball joint. So, now, here is what happened. Looking at how the drive shaft was in the way, I decided to disconnect the lower control arm. I don’t think this was a bad idea from the start since I was in a fully equipped shop, but it did lead to some problems that I would have had to deal with anyway. Basically, the front bolt came out with no problem, however, the collar inside of the rear lower control arm bushing was so badly seized that the cams used to align the steering would not budge. I tried every trick in the book and when it finally cam undone, the bolt was so badly damaged that there was no choice but to replace it. The way this setup works, is there is a metal sleeve with a cam on one end that slide through the bushing (also lined with a metal sleeve) through the rear of the front cross member. Since I could not push the collar out to get the control arm off, I had to knock the cam off the sleeve and grind the remainder of the collar off so the control arm would come off. Once out, I had to take the lower control arm to a machine shop to have them push the old bushing out. Of course, nobody within 90 miles had the bushing or the cam set so I need to wait until tomorrow to get them delivered. This little paragraph is the result of almost a full day of wrestling with that one bolt. Man. Also to get this bolt out, you need to loosen the steering rack. No problem since I was replacing the bushings anyway. My guess is that this sleeve seized since there were two dissimilar metals against each other. Maybe this is a poor design by Toyota. Either way, when the new bushing and sleeve goes in, they will be sure to have “no seize’ on them.
I know this sounds crazy and some of you will think I must have done something wrong but that darn bolt was seized beyond belief.
3rd. Steering rack bushings. This was pretty easy, it took maybe 30 mintes. Basically, I just cut the edge of the convenient side of the driver side and center bushing, sprayed a little lubricant and they slide out with just a little effort and twisting with a channel lock. I used white silicone lubricant to help slide the new ones in and keep them from squeaking.
Hopefully I will have the new bushing and alignment cams 8AM tomorrow to get this thing done. I figure that I would have ran into the same problem when I took the truck for alignment anyway. In a way I am happy it happened when I was installing the coilovers. Who know how much it would have cost me if an alignment shop had to deal with this. My guess is they would have left the cam where it was when it didn’t move and would have told me that the truck could not be brought into alignment.
I hope to finish the install in the morning. In a way I knew this would not go smoothly it never really does. I can say this, if I was doing this a second time I wouldn’t be hear writing this message, I would be out driving my truck by now.
I will post an update tomorrow on how the rest of the install went.
